Some of the problems I have not yet remedied:
-Biggest problem in Montana = Engine lugging after extended use of cruise control w/ and w/o A.C. (worse with A.C.). I'm thinking electrical problem but unsure. using water eater and premium gas gets rid of problem until I use cruise control again. ( very annoying you can imagine)
- second biggest = Need to replace timing chain and serpentine belt.
AWD vehicle with two different types of tires (need new tires)
Need to replace "transmission shroud" to get upshifting back in tiptronic mode (says audi mechanic), still unsure about this one.
and I'm sure there will be more down the road, but until then only these are causing problems. Does anyone have any ideas about the lugging? by the way lugging is when the engine's RPM vary up and down, causing the car to jerk slightly when accelerating (standard and auto) and stopped (only in automatics). I asked someone else about it and they didn't know what lugging was so now I explain it. Any advice/help greatly appreciated!
indie.ianjones@gmail.com
