Cleaning out the garage. Here is everything I don't need. there are some pics up on the samba http://www.thesamba.com/vw/classifieds/ ... ?id=848689 Willing to ship all except the shortblock and head. Shipping to lower 48 only. I accept paypal or money orders.
-16V timing belt cover $5
-16V PL bottom end(super clean, still has cross hatching) $50
-3 bar FPR $10
-Girling 54 MK1 Front calipers for 10" rotors $40
-16V PL cylinder head(needs to be rebuilt) w/ stock camshafts(under 5k on them) $30
-16V scirocco ignition module $10
-Set of $ 30lbs injectors/315cc Bosch #0280155831(looks like they have been cleaned) $60
-Home made DIGI 1 N/A intake has co pot holder, fits onto stock g60 TB and uses a 3" Filter(ISV hook up needs to be sealed) $15
-16V Valves, used, one ceramic coated all but one of them $40
-MK1 Power stering setup $75
-Power steering pump with bracket(one of the mounting points was cracked slightly and welded) under 5k on it $20
-Preheater box from 16v scirocco $5
-16v CIS ISV/cold start injector mount $5
-MK2 jetta sidemarkers(one has some cracks but is holding together fine) $5
16v parts and some other stuff.
- Mrbubblehead
- In the passengers seat...
Re: 16v parts and some other stuff.
the mk1 power steering setup, will it fit my MK1 GTI? If so I would be seroiusly interested. What all does it include?
- Mrbubblehead
yes it will work just fine. I put a manual rack from a rabbit gti into the rocco and it fit just fine. there is a picture of it on The Samba, link above.
Hmmmm....
