CIS, A turbo, and a 1600cc engine
Posted: Nov Sat 21, 2009 8:14 am
Alright guys, going to college and having plenty of time to think about my next project i've come up with some plans. I wanna do an Aircooled CIS motor on boost. Im thinkin a mild 15 pounds of boost. I'll be running a 5th injector ran by a pressure switch that is tripped by the turbo pressure to send the extra fuel to richen up the A/F ratio under boost this injector will be mounted in the intake. The only snag i have come across is the Distributor, what distributor can i use for retard under boost, or if i can keep the stock dist with an audi 5000 vaccum retard canister..? Anyways, i have most everything figured out except the dist. And in theory my idea should work.. Now, i just need to source a 1600dp engine and a complete bug minus motor, the CIS system a turbo and a header. Any ideas are appreciated, thanks
