Clutch and 5th gear FS
busafied05
Vehicles: 03 Jetta TDI
02 Tahoe
05 Suzuki GSX1300r
Post by busafied05 »
I have a slightly used clutch for sale as well as fifth gear that came out of my 03 jetta tdi.
First the clutch; It is a LUK clutch kit with aprox 15k miles of use on it. The reason it is for sale is because I thought I had a failing DMF (so I had another one installed) and it turned out there were never any issues with the DMF or clutch :banghead: (it ended up being something else) . Long story short I am trying to sell this clutch that I didn't need. As most of you know driving in montana is mostly highway driving so there has been very little wear on the part. I can send pics if you are interested. I am asking $ 600 for the complete kit.
Second the fifth gear; When I had the clutch put in the second time I had the shop put in a .658 fifth gear to lower my rpms on the highway so I have an extra set. I have heard that the stock gear works good in the gassers but I don't know how true that is so check to make sure if you are interested. The gear has about 100k miles on it and I am asking $ 100.00 for it. Again I will email pics.
Thanks
2003 Jetta TDI (125k)
