I started with a '75 F250 farm truck with a knock in the bottom end, and upon pulling the pan found a couple of bearings that were out of spec. So I pulled it, dismantled it and sent to to the machine shop. As the pics go I will explain each step:
This is what I started with:
Pulled the front clip to get some room for the cherry picker and make it easier to unhook everything:
Radiator and support with AC setup:
Motor mount removal:
Up and out!
Clutch reference picture:
Getting it on the stand:
Pretty much torn down and looking at the bottom end - it went fast:
Yup...:
Mains and rods off and looking at the crank. Some scoring, but not too bad. People, remember to change your oil!
Casting #'s...:
Filthy pistons and rods:
Crank is out (yes I know it's on it's side):
Ok, so block, crank, rods and pistons went to the machine shop. Everything was tanked and cleaned up, new cam bearings installed and new freeze plugs. The block was deglazed, but not bored over and rods were resized .10 over. Crank is .10 over, and was a swap with the shop. All the needed parts were ordered: New cam (stock), lifters, oil pump, main and rod bearings, master kit basically. Cost was around $800 for all the work and parts.
Before I started I washed the block out and then gave it a protective coat of Old Ford Blue:
Continue:
Just before the cam install:
And it's in!
New mains:
One edge in and ready to seat:
All in...and notice the center main (yes it's in the CENTER! lol):
Lubage:
Crank installed and mains sitting:
New rings being installed:
Filthy rockers:
Rockers (one side) disassembled and cleaned up in the parts cleaner:
Rockers are back together (the other side was done too):
Oil pan cleaned and a fresh coat of paint:
You can see the crank and cam at 12 o'clock - ready for the new timing set:
Set:
Fuel pump eccentric and oil slinger back on:
Oil pump and pickup - getting ready to install the new pump and cleanup the pickup:
