Tuner for Audi 10v/20v Full Stage IIC Package
Are there any tuners in Montana that could help with install and programming for a 034 Audi 10v/20v Full Stage IIb Package On an MC2 motor? I eventually want to go 20V but for now I would like to get away from the stock fuel dist etc.
Re: Tuner for Audi 10v/20v Full Stage IIC Package
have a link to the kit? what does it entail?
- ValveFloat
- Vehicles: 1991 911
Not sure where you are located, but Autoworks in Bozeman (Four corners specifically) has experience doing stand-alone ECU installations. Tuning will be more difficult to find, particularly for a AWD car, I can't think of an established business off the top of my head.
I doubt there's any tuner shops in MT who can even follow what you are wanting. I bet there has to be a shop in the Spokane/CDA area, which is fairly close to you, so maybe check somewhere over there?
I would be looking for something like this:
Audi 10v/20v Full Stage IIc Package
Click to Enlarge
The ultimate package for the Audi 5-cylinder whether 10v or 20v, includes literally everything to convert to 034EFI including ECU, Fuel system components, wiring and ignition components.
Part included are:
-034EFI Stage IIc, preprogrammed for the application, with flying lead harness.
-034EFI High Output DIS coils with connectors and plug wire ends, quantity 5
-42lb injectors, balanced and flow matched with connectors, quantity 5 (Larger sizes available for additional cost)
-Air and water temperature sensors with connectors
-034EFI Fuel rail, choice of 10v or 20v
-034EFI fuel line fitting kit with fuel pressure regulator
-034EFI crank pulley and VR bracket
http://www.034motorsport.com/product_in ... cts_id=302
Click to Enlarge
Part included are:
Jack, I could probably swing that, provided we didn't have to do too much actual tuning with the ecu, but if it comes preprogrammed, you should be good.
034 usually is laptop programmed. This kit may be already done. if thats the case, this isnt a real difficult job!
Seen you driving down Broadway the other day. Love your car! Good luck finding an installer!
If stuff does,t work out with rennwagon there is a place in heydan lake called f2-tunning they are real good at what they do give them a call
Thanks for the info. Also I am happy that no one saw me stalled in the left turn lane at Mullan and Broadway at lunch hour in a ton of traffic. A nice policeman stopped the traffic and helped me push it into a parking lot. Turned out a little fuel pump fuse issue.digsmk3 wrote:If stuff does,t work out with rennwagon there is a place in heydan lake called f2-tunning they are real good at what they do give them a call
