How to fix my window?
I just got a 02 Audi A6 Quattro 2.7T and I am trying to get all the little issues ironed out. I am having an issue with the passenger window. If I roll it down when I go to roll it up I have to pull up on the back side of the window or else it binds up. Is there a way to fix it? If so what do I need to do? Help this bugs the piss out of me.
Re: How to fix my window?
i wonder if the window off track or the regulator might be damaged. take the panell off an see
Sounds like it's off track.
Either way you need to pull the door panel to check things out.
With the panel off you should be able to inspect if it's going off track. If not, it could be the regulator.
where you at? we fix stuff like that at my shop in Missoula all the time.
Thanks everyone for the help. I will dig into it this next Monday. Hay Rennwagen1 I am from Billings so the trip would be long for a window fix. Thanks though.
Yeah, I understand, no problem!.
Billings has a deep enough crew, someone should be able to help!
