DIY: Taking apart interior GTI
DIY and tech writeups
Mill3niumThr33
Post by Mill3niumThr33 »
Anyone have a bently that they could look up the procedure to take apart the rear side panels in a GTI MK4? I dont feel like doing the pull and pray procedure. I need to get at my speakers to install new speakers and eventually a carputer. Joe...brandon....anyone
ValveFloat
Vehicles: 1991 911
2003 Ducati M620
Post by ValveFloat »
I have the MkIV Bentley on my computer.
If my wife doesn't take it with her to Missoula this weekend we can print the pages you need. If she does take it we can do it next week.
pull and pray is my .02 :mrgreen: youll learn the first time :mrgreen: this shows my undying love for mk4s :mrgreen: ok get the bently :thumbsup:
Re: Taking apart interior GTI
Mill3niumThr33 wrote:Anyone have a bently that they could look up the procedure to take apart the rear side panels in a GTI MK4? I dont feel like doing the pull and pray procedure. I need to get at my speakers to install new speakers and eventually a carputer. Joe...brandon....anyone
Bro here it is:
Side trim, removing and installing (Golf 2-door)
Assembly overview
1 - B-pillar
2 - Speaker bracket
3 - Clip
Qty. 3
4 - Clip
For body flange
5 - Body flange
6 - Speaker
7 - Side panel trim
Removing
- Remove seat Page 72-30 .
- Remove backrest Page 72-34 .
- Unclip side panel trim - 7 - from B-pillar - 1 - and from speaker bracket - 2 - -arrow A-.
- Pull up side panel trim - 7 - slightly -arrow B- and separate speaker - 6 - connector if installed.
Installing
Install in reverse order of removal.
Notes: Before installing side panel trim -7- check clips - 3 - and - 4 - and replace as necessary.
Clip - 4 - secures the side panel trim - 7 - to the wheelhousing body flange - 5 -.
Wheel Housing Trim removing and installing (Golf 2-door)
- Remove press button -2- from stud -5-.
- Pull trim -1- off body flange -4- with clips -3-.
Installing
- Install in reverse order.
--Gotta love remote access...
for this sake i luv mk1&2 even more!!!!! very thorough mike nicely done
Mill3niumThr33
Thanks a lot!
Mill3niumThr33
Wasn't as hard as I thought it would be. Behind that peice surrounding the speaker are styrofoam and a foam pad in a plastic bag :confused: . I cut my speaker mount to fit 6x9's and wired those and my front speakers to a 650 watt amp and rewired my sub to a 400 watt amp. I've got some crazy alternator noise coming out of my speakers so I am going to reground the amps and finish up the wire hiding.
ah, ye olde ground loop sounds.... make sure the grounds are clean
i just installed my old JL Audio 1000/1 amp and 12W7 in my buddies golf II its so loud, just need to redo the door and dash speakers.
Mill3niumThr33
Yea I saw him when I was at work...well actually I heard him then saw him :mrgreen:
yeah, like he said, ye old alternator whine. I have been a stereo installer for 10 years and it is still the bane of my existence. Check your grounds. If you have more than one amp, try to ground them at the same point. Try a seat belt bolt, and scrape the paint around the bolt hole. Check your RCA cables, make sure the are not run anywhere near the power lead.(separate sides of the car!) If you must cross the power lead, do it at a 90 degree angle. Use twisted pair RCAs, (sheilded or unshielded, I prefer unshielded). Make sure the RCA connections at both the deck and amps are solid and tight. Check the gains on your amps, see if it goes away at a different gain level. If you are using any kind of external cross over or EQ, try eliminating it, to see if it goes away. Anyway, that is all I can think of for now. Good luck. I hate alt whine :thumbsdown: :thumbsdown: :puke:
