Hello,
So I have had my tires put on regularly by tire rama (and rotated every 6k miles). This last rotation I found out they lost my wheel key (again) and they put the wrong rated tire on. Apparently I have a 80k mile rated and my car calls for the 60k with higher speed rating. By doing so I was getting half the mileage out my tires and paying more for them (the first set they gave me a rebate since they didn't last). My question is that since Tire Rama is going to deny they lost the key is there any way of getting that one lug off so I can replace it with a regular one. I know in order to get the key I have to go to the dealership but I can't justify paying $50-60 for that part.
FYI, Tirerama in Missoula on South said that the reason I wasn't getting the mileage was because VW are notorious for chewing up tires....I guess so when they are not the right ones.
lost wheel Key and wrong rated tire
- n00b...
- Vehicles: 03 Jetta TDI
02 Tahoe
05 Suzuki GSX1300r - Location: Florence, MT
2003 Jetta TDI (125k)
- Darkside
- Vehicles: 97' Jetta VR6
Re: lost wheel Key and wrong rated tire
Maybe you could get a key at a wrecking yard?
find someone with the key and have them remove it for you?
- n00b...
02 Tahoe
the problem is (according to VW) there are several different key sizes. I guess in theory they prob. only made so many sizes for 03 and I could try that but it could be a wild goose chase.
- Darkside
find an 03 tdi at the yard and try the key from it????? I am sure you can find or borrow one.
A large pipe wrench. It should do the trick.
- n00b...
02 Tahoe
well got it off thanks to import palace. I just had them get 4 luggs from the dealership. But what is interesting is there was another jetta there (03 just like mine) and her lug key didn't fit on my jetta. Either way thats done. thanks for the replies.
