First thing you will see is the yellow oil can icon with the word "SENSOR" in your DIS:
Scan it, and you won't see a code. Or at least I didn't, so I understood it was a mechanical problem with the sensor. I went with the Meyle OEM replacement, which is a German part, but ironically has a Made in China sticker on it
Here's a couple of pictures of the Meyle replacement:
So onto the DIY part - If you still have your splash guard, remove it. Drain your oil. I decided to drain my existing oil into a clean gallon milk jug with the top cut open for easy filling. Some may ask why, I run Amsoil, which was recently changed and will last longer than most synthetics, and it's expensive. So I wanted to save it until the next time to change, which is in a couple more thousand miles. You may opt to do this on a regular oil change:
From there, you will see the sensor bolted in the oil pan. Remove the sensor connector (already unplugged) and unscrew the three 5mm hex bolts. Then simply pull the sensor down and out of the pan. Keep the black metal cover and save it - it will be used on the new sensor:
Old and crusty, pics to compare to the Meyle part. Pretty much the same...I would suspect they are more than likely made in the same factory:
Thoroughly clean the sealing surface of the oil pan in prep for the new sensor install:
Clean up the bolts and the metal cover:
Installation is the reverse of removal of the old sensor. No additional sealant is needed, the rubber o-ring is double lipped and is more than adequate. I couldn't find torque values in the repair manual, but use common sense here and tighten until snug, and don't over-tighten, or you will be replacing your oil pan. Plug the connector back in to the sensor, and the job is done:
