86 Jetta
86 Jetta
Picked up this 86 Jetta the other day. Going to put some much need lovin on it and it will replace the MK4 VR as the GF's daily. The Jetta is a little rough but, it should clean up. The immediate concerns are a new cluster (CE1) cause the speedo is dead in the car now. And a fuel pump :( Also looking for a set of wheels...
I like my driveway like this :)
benno3231
Re: 86 Jetta
Post by benno3231 »
Beautiful lineup of dubs brotha
benno3231
Re: 86 Jetta
Post by benno3231 »
Oh i figured out what car that cluster is for. duh. My bro has a spare cluster i'll check with him and get back to you
benno3231
Re: 86 Jetta
Post by benno3231 »
I assume you have checked the speedo cable right?
Re: 86 Jetta
CIS-E, Jetta, 8v, I'm pretty sure that MK2 has two pumps - one in the tank, the other inline. If it fits, I'm sure we can make a deal if you want my used inline pump, but I don't think it will fit the MK2. I could be wrong.
A couple of things to check if the problem is intermittent would be the ignition switch and the fuel pump relay. They both are common failures that cause the main pump to be MIA.
Re: 86 Jetta
Its a wolsfburg too :)
Re: 86 Jetta
It is a wolfy. I think the speedo cable is good. I think it is the external pump, it is loud. lol
86 Jetta
You will want to measure the outside diameter. There are like 3 sizes. My guess is the 60mm
Re: 86 Jetta
Cool I was reading that there are 3 sizes. I will get on it :) keep the info coming. You have mad MK2 knowledge.
choncho
In the engine bay...
Vehicles: jettas n a 3/4ton
Re: 86 Jetta
Post by choncho »
