These things are beefy. 12V VR6 Heavy Duty H-Beam rod set with ARP hardware. Item # BDM.164.20H, feature a 20mm pin bore and ARP bolts. Precision balanced set of 6 rods. 580g. Suitable for turbo or high mileage applications. Brand new, never used. These have been out of the box and had pistons mounted for about an hour but never installed in a block. Brand is Bildon but same manufacturer as 95% of other similar rods that everyone puts their names on. Must be used on 82MM bore or larger and will need to be installed from the bottom of the bore by attaching the piston above the deck. If you wish to install from the top you will need 84.5MM bore or larger (R32). Price: $575/set shipped; some savings from buying directly.
-Andrew
