Could not get a good shot of oil in spark plug "hole". But these are the plugs I pulled out.
Assumption is valve cover gasket and spark plug "hole" gasket. Right? I assume the gasket just wears out 118,000 miles and over 11 years old.
Ordered replacement valve cover gasket set and timing chain tensioner gasket set (half moon, not sure if this area is leaking but rather have it than not have it). Product links below. Should the plugs and coil packs be replaced after the gasket is changed due to those parts being exposed to oil? Coils were warranted out two years ago via Dana.
http://www.mjmautohaus.com/catalog/prod ... ts_id=1306
http://www.mjmautohaus.com/catalog/prod ... ts_id=1310
Now when I started it to check if it was running it shot blue smoke out the back killing any mosquitos
Sorry for so many questions and for writing a book trying to be thorough.
These are the DIY I found on Vortex. Does not seem too hard 1-2.5 hour job start to finish.
http://forums.vwvortex.com/showthread.php?2035487
http://forums.vwvortex.com/showthread.php?4341168
