1980 Rabbit Diesel C 2 Door White on Lipstick Red
67,893 miles. Not verified. But body shows it may be true.
The body has some scratches on the hood and small marks of surface rust on the side. (see pix)
Here is the project thread that had most of the information:
http://eurowerks.org/showthread.php?t=42894
Everything appears to be stock. Minus the engine swap but the 1.6D is Stock
I did remove the 1.5D and installed a running 1.6D mated to a 5 speed trans (code FN 20101)
I changed the oil and filter with a NAPA filter and Rotella 15w-40
Installed a new v-belt
New valve cover gasket
New NAPA air Filter
New fuel filter
Drained the old diesel fuel and replaced with #2 diesel with Howes Diesel additive.
It will have a new battery
New 5 speed linkages (dog bones) that comes with the bushing kit.
-Major Items to be addressed:
Finish up the 5 speed swap. I believe that it needs the reverse lock out box mounted under the shifter (exterior). It will go into every gear. You have to push down and over to get into 1st and 2nd.
Timing belt replacement. The installed looks good, but it’s a peace of mind thing.
I have not installed the transmission mount. I cannot do so because of my limitations on my back
Change gear oil
Tires will need replaced. It has 13” tires on it now. Tires currently hold air and have some tread on them.
The hood latch and cable will need replaced.
Driver side window regulator works, but needs replaced. The tube fell off and the end catches on the inside of the door.
Some new hose clamps are needed. The very small ones. Fuel return, Top of radiator.
-Included in the sale is the 1.5D and 4 speed trans. I don’t not need them and cant store them.
A lot of NOS odds and ends. IE; fuel hose from tank to hard line. A fuel injector, etc
Non-A/C bracket with pulleys.
The orginal A/C condenser and the compressor will be included.
I can include wheel dollys if the buyer wants them. So it can be rolled around the garage.
I will provide more pictures upon request. Please feel free to ask me any questions. I will be as honest as I can and provide as much info as I know.
I am selling this because I cannot go back to work another month. I will list elsewhere but would like to see this go to a good home on here. First with cash takes it. No trades. I will not hold it unless a non refundable deposit is made. The car sits in my heated garage at the moment to keep rodents from invading the interior.
I have not driven this more than around the block to see how road worthy it is. I like to think it would make it to the MSP area, but give no guarantees.
$3500 FRIM. This cost includes everything listed and myself trailering it to Billings. I can trailer farther for additional cost. I will tarp the car to help against rocks/weather.
Meet in Glendive: $3350 FIRM. Bring a truck/trailer. ~250 miles from the MSP area.
$3000 FIRM if you come pick it up at my house. ~500 miles from MSP area. That includes all the extra parts too.
I will not lower the price if the extra engine/trans are not taken. I don’t need them and cant sell them up here.
No trades
Located in Minot, ND. ~500 miles from MSP area.
I can be reached at 701-340-6011 text/call or PM
A video of it running: the video sound is out of sync.
This is the 1.5D that comes with it.
Dealer installed A/C system:
The only bit of rust I found on the car
Some red marks on the roof
