-In Helena
Most parts swapped from my totaled 94 passat
-OBD1 12v VR6 swap
-5 speed swap
-Manual brake booster swap
-Full 94 suspension
-ST coilovers, low miles
-Toyo G-02 plus tires, great shape, low wear
-About 85k on the engine
-Intake ported to 2.9
-200k+ on body, Arizona car, super clean minus some dings
-custom built stainless 2.25 exhaust with Eurosport tips
-Front and rear drilled and slotted rotors, rears swapped from Corrado
-MK3 sunroof swap with glass from B4
-European GT flares and door/rocker panels
-European textured bumper
-CA/Euro dash pockets and manual seat belts
-Full poly subframe bushings
-Rear bumper sill needs to be stripped
-Currently has black leather seats, with MK3 fronts, may include the leather depending on sale price, or sell separately
-Also have full swap for grey or blue cloth passat seats
-May include Thule rack
-Recently replaced Driver side hub, wheel bearing, and CV axle
-Replaced starter
-Replaced crackpipe, thermostat, thermostat housing and gaskets
-Dual slimline fans on custom mount to a radiator that's only a few years old
-New condensor and evaporator
-Ford Coilpack mod
-B4 Passat center console
-Have extra door, hood, bunch of other bits n pieces
Cons:
-Needs some new suspension bushings
-Power steering must have water in it, tried cleaning it, ran 4 bottles of the oem fluid through it. Still milky, a little whiny
-Valve cover gasket leak
-Some vacuum lines possibly missing
-heater box resistor out, blower motor wired to a switch currently
-sunroof broken, have extra
-Recently developed a stalling issue, thinking crank position sensor
-hatch busted up from hit and run
-Overall a solid running car, but could use some tidying up, sure I'm forgetting a few things
Since it's nice out, I'm hoping to fix stuff as I go along here, I'll update this post. If I get it all completed, I'm hoping to sell it for $2100 OBO, possibly more with the new parts on it. But as is, make me an offer if you're interested! Or pm me with parts offers, give me something to think about.
Message me with any questions
Thanks,
Keegan
