Because I can't figure out what is wrong with it...
Here is what it does, besides not work..
When I turn the fan speed to 1, the compressor will turn on, and the lines will get icy cold and there is a load on the engine, BUT the blower fan will not run.
When I turn the fan speed to speeds 2,3, or 4, The fan will run, but the compressor will turn off. (on speed 4 I also get some nice little specs of foam.. lol)
Fix My AC... Please? I will supply cookies.
Re: Fix My AC... Please? I will supply cookies.
I'll put my money on the blower motor resistor pack going bad...Roadhog wrote:Because I can't figure out what is wrong with it...
It's behind the glove box, and screws into the blower housing - see what happens if you unplug it. Mine was dead and would only blow on 4 - no AC.
Did your AC Compressor shut off on speed 4 then? Thats what I find odd...MikeWire wrote: I'll put my money on the blower motor resistor pack going bad...
