I say keep it the original color, but you should throw some pearl or metalflake in there to set it off. That way your jams and engine compartment will still work.
1.8/2.8/3.2 OEM+ You can pay for school, but you can't buy class!
Rennwagen1 wrote:I say keep it the original color, but you should throw some pearl or metalflake in there to set it off. That way your jams and engine compartment will still work.
the jams and engine compartment are probably getting sprayed too. Since I will have everything tore apart for the transmission swap.
The paint on it now is a pearl. I might get it a bit more metallic, like you said.
