Need some help with pedal input lag
VWJET00
Post by VWJET00 »
k i want to get rid of the delay in pedal input. when i put the pedal to the floor it takes like a second or half a second for the car to get moving. I was reading on some sites and it says that if you reflash? the ecu or something like that it helps. i really don't know what i can do to fix this. so i need some help thanx!
~VR6JET~
thetwodubheads
Vehicles: 2012 Golf TDI, 2010 Ram 2500 Cummins
Post by thetwodubheads »
It depends on the delay, I don't think the reflash can really get rid of it. The ecu can only comprehend inputs so quickly. You may have an issue with the throttle body or the pedal/sensor itself. I'd suggest checking those out before trying to get it flashed to "fix" it.
MK 4 GTI
Post by MK 4 GTI »
Any check engine or EPC codes?????????
I would suspect that a slight lag may be normal.
2000 MK 4 GTI 1.8t
1994 Ford F-150 4X4
CBCGSXR1000
Vehicles: 2
Post by CBCGSXR1000 »
I can scan it to c if anything comes up.
Let me know when u can :D
CHRIS
I have heard about something like this on the Touared forums, they refer to it as "Death Lag" meaning it always happens when you are trying to make a break in traffic. I have never had this problem with mine, but I have always had the update flashes done. There are a few "ways" I have heard of to fix it, a few you can try yourself, and then always a flash update from the dealer. I am not sure if they transfer over to your car, but you might do a *sigh* VWVortecks search on it and see what you come up with. Sometimes that site can be some help.......
