Scirocco F street prepared engine options????
76scirocco
Post by 76scirocco »
A few too many revs at top gun and now my 1.6 is smoking pretty bad. Does anyone have any leads on a engine set up which will keep me legal in FSP, but give me a little more power. Rulebook says I can swap in anything from the same line in appendix. This means any 8V scirocco engine, so what is the top dog engine??
2.0 xflow. get one from a pre-95 car.
just dont run it on obd1. go digifant.
if you plan to keep it counterflow get a JH head and put it on an ABA bottom end.
or if you get real crazy put a JH head on a 16v bottom end (13.6:1 comp)
btw you were spotted with the rocco on a trailer passing through East Helena a day or 2 ago ;)
ie all mk1 sciroccos came with a 1.5, 1.6, or 1.7. mk2 roccos got the higher compression 1.8's
76scirocco
The biggest engine in a scirocco is a 1.8 then? For the class it has to be a scirocco mk1 or mk2, or any VW mk1. It also has to be an 8V. I guess that what I need is a 1.8 with a big valve head?
Check the rules on overboring also, I believe you are allowed a first overbore(.020) and still remain class legal. In the SP classes you might be able to get a second (.040) that way you can start with a 1.8L and get some more displacement out of it.
I B GOLFIN
Post by I B GOLFIN »
Ive got a brand new 1.6 liter with about 200 miles on it if your interested.
76scirocco
What kind of money for the 1.6? Does anyone have a rebuildable 1.8?
I've got a rebuildable 1.8 and 1.7
76scirocco
I am definitely interested in the rebuildable motors. I might have to run up there one of these days and check em out.
