Santorin A4 :P
Re: Santorin A4 :P
bmx_a4 wrote:I can't wait to see your rabbit! If I play my cards right, I'll be slowing collecting parts and get the motor and head work done all at once. (I have a spare motor I'll be using) It's gonna be sweet!
It always helps when you have spare motors and parts laying around too! :thumbsup: :D
Re: Santorin A4 :P
You bringin the whole Family in the rabbit? :) or you bringin the mk4 too? it will be a blast having two mk1 16VT's your in for a treat. a rabbit should never pull this hard :)
bmx_a4
Vehicles: 00 A4 Quattro 1.8T
98 A4 2.8 - RIP
Re: Santorin A4 :P
Post by bmx_a4 »
StaggeredMK4 wrote:]It always helps when you have spare motors and parts laying around too! :thumbsup: :D
For sure. lol. Motor is sitting in Sheridan, WY at my dad's right now though haha. Gotta pick it up at some point in time. (It'll definitely need a bath and some lovin) :D
2000 A4 1.8TQM -
Re: Santorin A4 :P
kompressorgolf wrote:You bringin the whole Family in the rabbit? :) or you bringin the mk4 too? it will be a blast having two mk1 16VT's your in for a treat. a rabbit should never pull this hard :)
Mine won't be turbo'd by YNP unfortunately. Just don't think i'll have the money for all that good stuff just yet.
Ha ha the whole family in the rabbit! Don't think they'll fit well in back with the roll cage! lol
I'm not sure if they are going to make this trip. Might just be me this year, not sure yet.
bmx_a4
98 A4 2.8 - RIP
Re: Santorin A4 :P
Post by bmx_a4 »
Update :
Given the price that I got from Laszlo at 034 I'm gonna end up going with a 2.0 stroker kit.
Brandon, about how much did all your motor and head work run you at ICM?
2000 A4 1.8TQM -
Re: Santorin A4 :P
250 for the head, but i got loads of shit done. decked, new guides, 3 angle valve job, all new valves and seals. then 300 for the block, decked, bored, honed, new IM shaft bearings, and a thorough cleaning.
Re: Santorin A4 :P
bmx_a4 wrote:Update :
034 is awesome :thumbsup:
Stoker kit with the polished knife edged crank? Those are nice they show up in a wooden crate just the size of the crank shaft....it is pure sweetness when you open it :nod:
bmx_a4
98 A4 2.8 - RIP
Re: Santorin A4 :P
Post by bmx_a4 »
Darkside wrote:034 is awesome :thumbsup:
I can't recall about the crank right now, but I know that when I scrape the money together the kit is gonna include the following :
ABA CRAKSHAFT, 92.8MM STROKE, FOR USE IN 058 BLOCK WITH PROPER
CLEARANCING
SCAT 4-CYLINDER ROD SET, 144MM LONG, 20MM PIN 1
JE FORGED PISTON SET, 1.8T, 82.5MM BORE, 92.8MM STROKE, 9.0:1 COMPRESSION
RATIO
BIG BORE HEAD GASKET, 1.8T, 83MM
ARP HEAD STUD KIT FOR EARLY 058 1.8T, 11MM
ARP MAIN STUD KIT, 058 1.8T
COATED 058 1.8T ROD BEARING SET
COATED MAIN BEARING SET, 1.8T
COATED THRUST WASHER SET, 1.8T
And to top it off, there's a small discount applied since I'm an Audizine member lol.
kompressorgolf wrote:250 for the head, but i got loads of shit done. decked, new guides, 3 angle valve job, all new valves and seals. then 300 for the block, decked, bored, honed, new IM shaft bearings, and a thorough cleaning.
Sweet! That's not bad at all! I'm definitely gonna look into going to those guys.
2000 A4 1.8TQM -
ryan's05gli
Re: Santorin A4 :P
Post by ryan's05gli »
still probably want a limited slip for the back anyways if you ever want to turn up the power. and if it were me and money was no object. skip the GT-RS and go for the new GT-X turbos. that is if money is no object anyways... haha
2005 VW GLI - pretty much stock. for now...
Re: Santorin A4 :P
Nice that is pretty standard. I heard it is cheaper if you have an 06a block because you can use a 2.0 fsi crank and no clearancing required. My old roommate was building one of these went crazy spent crazy money. lol Check out http://www.qedpower.com BobQ is the 1.8t GOD :D
I will try to find pics of the polished, lightened, knife edge crank the old roomie bought.
