EPC LIGHT
- CBCGSXR1000
- Vehicles: 2
EPC LIGHT
DOSE ANYONE KNOW WHAT THE EPC LIGHT MEANS. BOUGHT CAR USED DONT HAVE MANUAL. IVE REPLACED SOME THINGS JUST LOOKIN FOR A TIP TO WHAT IT COULD BE
CHRIS
WHAT CAR ARE WE TALKING ABOUT!!!??
- CBCGSXR1000
- Vehicles: 2
epc light
CAR IS 01/JETTA. I have some mods coldair,full exaust magna flow oem cat ,atmosphiric blow off valve, autotech sport tuned fuel rail,4.0 bar fuel preshur ragulator,and the n75 valve. light comes on 5 days after being cleared.then pops on here and there when its on car runs bad if its off it runs good.Sometime the traktion,and check engin light will turn on also.Had its in shop havent fixed it been back 3 time. if u got an idea it would be great. sory about bad spelling.
CHRIS
Re: epc light
Mainly Aeron is asking what motor - with a BOV I assume you have the 1.8 (unless you have a VRTCBCGSXR1000 wrote:CAR IS 01/JETTA. I have some mods coldair,full exaust magna flow oem cat ,atmosphiric blow off valve, autotech sport tuned fuel rail,4.0 bar fuel preshur ragulator,and the n75 valve. light comes on 5 days after being cleared.then pops on here and there when its on car runs bad if its off it runs good.Sometime the traktion,and check engin light will turn on also.Had its in shop havent fixed it been back 3 time. if u got an idea it would be great. sory about bad spelling.
Doesn't seem to me that any of those mods should throw an EPC light, but maybe the CAI. So a couple of questions....
Does it drive normally, or does it bog down?
Have you had it scanned with Vag-Com or just cleared (with a generic code scanner)?
I can scan it and tell you exactly what's wrong and probably how to fix it. Just email, PM or post up in the thread.
Re: epc light
I hear that a BOV will cause an EPC light. Since the ecu doesn't know where all that air went.MikeWire wrote: Mainly Aeron is asking what motor - with a BOV I assume you have the 1.8 (unless you have a VRT)
- CBCGSXR1000
- Vehicles: 2
EPC LIGHT
Its a 01/JETTA/1.8T.Yes it bogs down.HEARD BOV ALSO THOUGHT ID ASK U.Dain motors in billings scaned it so dont know what they used.If u can scan it and help tha would be great.
CHRIS
Yeah, since the VAG motors don't like atmospheric BOVs, (my shop eclipse 4G63 is the same way, have to recirc) I would try that first. What BOV do you have on it? I have some TurboXS recirc valves available. I am willing to be it is air related(meaning not fuel, or spark)
Aeron's correct - if you have an atmospheric BOV (not routed back to your intake), then it will cause problems by running the car too rich. I can scan it, but more than likely the problem will be that you need to get the correct BOV (get that TXS from Aeron) or go back to stock. I'll at least clear your codes for ya, which will take your car out if limp mode. I hate to ask, but what did Dana charge for a scan? I use the same software they use.
What BOV do you have now?
RBV-25 Aeron?
RBV-25 Aeron?
- CBCGSXR1000
- Vehicles: 2
EPC LIGHT
BOV is HKS not sure what type was on it when i got car.I have a diverter not on i would like TXS have how do i get ahould of u?
CHRIS
