Smoke more faster. DIY smoke machine.
DIY and tech writeups
Post by uberaudi »
It seems like every older German car has dealt with vac leaks in some form or another. They can be obvious at times and easy to find or a real frustrating ordeal. So when the propane and carb cleaner tricks aren't getting you anywhere, another valid option is a smoke test. Here's my take on a smoke machine from an accumulation of ideas all for about 5 bucks and 20 minutes of your time. Ahhh, it's even my first DIY here.
To start out I collected the neccessary parts. A peanut butter jar, a couple hose fittings, and of course some Black & Mild's. You also need a pump which can be seen in later pics.
Next I used a step drill to make a couple holes in the lid just big enough for the fittings to push in then ground off the paint/coating:
A little flux and solder and the fittings were leak free. You can see the battery operated air mattress pump I used in this pic but I'm sure any low pressure pump could be made to work:
Now take a Black & Mild and whittle the wooden tip down enough that it pushes into the backside of one of the fittings, leaving some air gaps on either side:
Make a hi-tech adapter for the air pump:
Attach some hoses and flip the pump on. Look at that cherry glow!:
And a difficult to capture shot of the output. It definitely puts out some smoke. My small garage was cloudy in no time:
I think this should be adequate enough to tell me what I need to know. I have good feelings about this.
Re: Smoke more faster. DIY smoke machine.
that is some GEANIOUS work!!!!
Very nice pice of genius.
Love it! I'd like to see some pics or a vid of it in use.
And I gotta ask...any reason for the Black & Mild's in particular?
I have that same mattress pump. I use it to get fires started :)
Post by uberaudi »
But do you have the same smoke machine? I tried it out today and it worked great! I have a pretty good sized leak coming from my throttle shaft on both sides so it looks like it's time for a rebuild. It turns out smoke is hard to take a picture of but if you look real close, you can see it on the left side of the TB:
