Electronic Boost Controller
Well, there it is. Joe nailed it. Not surprising, really.... :beer:
CBCGSXR1000
Vehicles: 2
Post by CBCGSXR1000 »
Rihgt on thanks for info. Ill look into that more.
:thumbsup:
CHRIS
ValveFloat
Vehicles: 1991 911
2003 Ducati M620
Post by ValveFloat »
Thought about this a little more. Most of what I posted previously had to do with the turbine side of the turbo. On the compressor side, I suppose the outlet of the small compressor could be connected to the input of the larger compressor in a sequential set-up. That way the pressure on the inlet of the large compressor would be above atm, so it would spool quicker, in theory. But as the rpm climbed the small compressor would still probably be outside its best efficiency, and would just be a restriction. This may be the way the RX-7 works, because after the second turbo kicks in, the torque doesn't climb like you would expect it to.
-Joe
My cars
Mill3niumThr33
Post by Mill3niumThr33 »
ValveFloat wrote:
The newer and better solution to sequential set-ups is the variable vane turbo.
If you can get Porsche or the diesel manufactures to release specs and designs on variable vane turbos I'd love to see them. They are all so tight lipped about them its crazy.
CBCGSXR1000
Vehicles: 2
So juet going with a big ballbaring turbo would be
good enought for a 1.8.Well it will get me 400hp.
Thats what my goal will be dont got the cash yet :banghead:
CHRIS
Mill3niumThr33
400 wheel hp or 400 crank hp? Thats a lot of power for a front wheel drive car IMO. A guy back in MN has a 1.8t with a t3/t4 putting out 350+ whp and wtq and he has trouble getting traction in the first 3 gears. I think anything above 300 whp on a fwd is a little ridiculous but thats just me.
CBCGSXR1000
Vehicles: 2
I c.Ill have to do so tinkering with that car might
need more waight in front maybe beter tires or lsd.
I think if i fucked with the gearing there could be
a way to make catch. By then should have
stroker kit.witch wont help with traktion maybe
ill have to put some real money in tires.
Already lookin at stage4 susp.kit but thats
good to know he might have tryed it all
will c thanks and ill take any more info.
u have on it. :)
CHRIS
ValveFloat
Vehicles: 1991 911
2003 Ducati M620
Mill3niumThr33 wrote: If you can get Porsche or the diesel manufactures to release specs and designs on variable vane turbos I'd love to see them. They are all so tight lipped about them its crazy.
Hmm, I didn't realize that Aerodyne was no longer in business. They made variable vane turbos that were available to the public.
-Joe
My cars
CBCGSXR1000
Vehicles: 2
If i can fine one ill get it but whos knows
what kind of luck im have.It would be sweet .
CHRIS
CBCGSXR1000
Vehicles: 2
Any word on REVO :ninja: hunt them down
CHRIS
