codes from cel need help
Discussion regarding the software diagnostic solution
VWJET00
Post by VWJET00 »
okay so a buddy and me scanned my 2000 vw jetta vr6 today and i got the following codes. P0420, P0411, P1196, and P1137 pd. I figured out that the P0420 was prolly my engine temp sensor being that my temp gauge rarely comes up. P0411 is either my secondary air injection pump or selenoid valve *which i have no idea what this is!*, and P1196 is my pre cat 02 sensor. the last one i have no idea and i searched for it but had no luck if someone could help me out that would be great thanks a lot!
~VR6JET~
CBCGSXR1000
Vehicles: 2
Post by CBCGSXR1000 »
Did u us vag com it will tell u what each one is?
I will look it up later no time right now.
I have vag com if u want to swing by :thumbsup:
CHRIS
Well, I am not sure what the rest of the codes are, but the secondary air pump is fairly common on the Vr6s, in fact I have the same problem. The pump pushed fresh air into some part of exhaust system on startup that helps the cat heat up faster so the 02 sensors do their job faster. Mine has been bad for about 3 years now, and the only problem it can lead to(other than the CEL being on) is premature cat failure, but I have not had any problems with it. One of these days I am going to fix it, but I haven't really felt like it for the last 3 years or so. Car runs perfectly, so I will get to is sometime.....
Here you go Joel:
VAG-COM Version: Release 311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 021 906 018 M
Component: MOTRONIC ME7.1 G V006
Coding: 00031
Shop #: WSC 00066
1 Fault Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
Readiness: 0000 1101
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13204
Shop #: WSC 00066
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J0 920 900 J
Component: A4-KOMBIINSTR. VDO V59
Coding: 07262
Shop #: WSC 02338
IMMO-IDENTNR: VWZ7Z0Y2186151
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-00 - Open or Short to B+
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AJ
Component: 61 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00066
2 Faults Found:
00912 - Window Regulator Switch: Front Left (E40)
27-10 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
End -------------------------------------------------------
MK 4 GTI
Post by MK 4 GTI »
420 is the universal code for CAT
2000 MK 4 GTI 1.8t
1994 Ford F-150 4X4
MK 4 GTI wrote:420 is the universal code for CAT
CATS that like the BONG!!
No, really, it doesn't say anything in there about the secondary air pump, though. :question:
Is a code for the pre-cat O2 sensor. More diags are needed to diagnose the real problem with the sensor, but for $25 he can replace it, which probably needs to be done anyway considering his mileage.
He also should get the green top coolant sensor and the o-ring too. I'm not that familiar with where it is on the VR, and I could look it up but I would imagine that one of you guys would know where it's at and maybe explain it better.
Couldn't find anything on the SAI pump, so I figure it's a misdiagnosed code. Some of the early 00 models don't even have one, and I didn't verify that. I you need more help Joel let me know and we can meet up another night.
VWJET00
Post by VWJET00 »
for sure mike i have to wait until i get my tax return for those sensors but for graduation i get my exhaust from my dad i guess so im excited. now its just a matter of finding a cam and intake. lol hopefully summer is good the the getta! thanks for you help mike!
~VR6JET~
