Heater not warm
paintballguy424
69 Beetle
Heater not warm
Post by paintballguy424 »
Ok so when I bought my car in Feb. the heater didn't work :banghead: . Figured maybe just needs to work whatever it has in the system through. But now August still no heater. Engine temp sits at 190 no overheating all hoses look intact and warm when tested. Coolant level ok, cabin air filter ok. Ideas heater core?
Thanks
Cole
1969 Beetle
Re: Heater not warm
When I replaced the water pump and changed the coolant on my 8v, the heater went from barely blowing warm to almost too hot. Could also be a vacuum issue with heater controls (consult uncle bently).
Re: Heater not warm
Cole do you have climatronic or manual controls? Trevor is right if you have climatronic, but if you have manual controls they are old school cable IIRC.
Re: Heater not warm
could also be stuck open thermostat, although it would get pretty warm eventually. does it have any trouble when you try to switch the air from defrost to the floor? i.e. doesnt blow to the floor just defrost regardless of direction switch>?
paintballguy424
69 Beetle
Re: Heater not warm
kompressorgolf wrote:could also be stuck open thermostat, although it would get pretty warm eventually. does it have any trouble when you try to switch the air from defrost to the floor? i.e. doesnt blow to the floor just defrost regardless of direction switch>?
It will defrost, and the air does move position to position.
MikeWire wrote:Cole do you have climatronic or manual controls? Trevor is right if you have climatronic, but if you have manual controls they are old school cable IIRC.
Manual controls if that helps.
MT-Getto wrote:When I replaced the water pump and changed the coolant on my 8v, the heater went from barely blowing warm to almost too hot. Could also be a vacuum issue with heater controls (consult uncle bently).
Sounds about right with the water pump but wouldn't I have other issues overheating etc.?
1969 Beetle
Re: Heater not warm
Sounds like your heat/cold blend flap is not working correctly and/or is stuck on cold. If you aren't overheating then it's not your thermo or your pump.
paintballguy424
69 Beetle
Re: Heater not warm
MikeWire wrote:Sounds like your heat/cold blend flap is not working correctly and/or is stuck on cold. If you aren't overheating then it's not your thermo or your pump.
Is this located inside the cabin or in the engine bay?
1969 Beetle
Re: Heater not warm
As far as I know, it is in the cabin, up under/behind the passenger side dash.
Re: Heater not warm
HVAC control cables are of course right behind the manual knobs, just remove the cover and there should be 4 T25 screws holding it in. The rest is behind the dash, behind the center console/lower kick panels like Aeron said.
paintballguy424
69 Beetle
Re: Heater not warm
Alright thanks for the all help.
1969 Beetle
