what is the easiest way???>
what is the easiest way to get all that crap off the floor of rabbits, the insulation stuff under the carpet padding, i hope its not a puddy knife ive been doin that for hours, with little results, all that glue too :puke:
Just a shot in the dark, but how about a grinder with a brush wheel, a mask, and a shop vac?
PoorHouse
Vehicles: 78 Rabbit
Post by PoorHouse »
I used a heat gun to warm it up a little then a putty knife. Came off real easy. Cleaned up the remaining stuff with a wire wheel.
Also heard dry ice and a hammer work well.
ValveFloat
Vehicles: 1991 911
2003 Ducati M620
Post by ValveFloat »
I have also heard that dry ice makes that job easy. The way it was explained you lay pieces of the ice on the stuff and gets super brittle so its easy to scrape off.
A fellow autocrosser did this to his CRX and the results were impressive.
Custom VW
Post by Custom VW »
wish I would have remembered that trick... :angry: I ended up buying a rubber wheel for the grinder. dry-ice is frickin cheap
Custom VW wrote: dry-ice is frickin cheap
And fun at Halloween parties! :ninja:
