WTB: B6 A4 parts car or junkyard parts
Classifieds category for Audi parts and cars
Guys, I am getting parts collected for a manual swap. I either need a cheap parts car, which would be ideal, or a junkyard where I can pull the parts from. If anyone knows of any B6 Audi A4 2.8 or 1.8T for sale (wrecked, salvage, etc.) please let me know.
Here's the parts I am needing:
  • brake/clutch pedals
  • clutch master cyl
  • clutch slave cyl (early B5 one, they're metal)
  • brake master cylinder reservoir to clutch master cylinder hose (6” of rubber fuel line would be fine)
  • clutch slave cyl hard/soft line (braided stainless steel soft line, makes install easier)
  • manual transmission (B6 from 1.8T or 2.8)
  • manual transmission crossmember or side mounts (must match manual transmission)
  • manual transmission front CV halfshafts (must match manual transmission)
  • clutch fork (must match manual transmission)
  • throw out bearing
  • shifter assembly/control rods
  • flywheel/clutch disc/pressure plate
  • 43mm bearing for use as a pilot bearing (or the 3.0 pilot bearing, cut to fit)
  • rear differential that matches final drive of the manual transmission you're using
  • front to rear driveshaft (must match manual transmission)
  • manual transmission downpipe
Holy cow!
Re: WTB: B6 A4 parts car or junkyard parts
I know, sounds like a lot, but it's not that bad. It would be nice to have a parts car.
I'll see if the Russians around here have one. O_o
Ooo yea please. I think I sent one of them an email, but I may have overwhelmed them. Let me know Jason :)
I gotta get an in somewhere with someone near Billings that does car auctions or something with wrecked cars, esp. Audi. When Wade and I went picking, we found literally no Audi's. Wonder where they all are going...
does it have to be a wag9on or sedan????????
Either, doesn't matter at all.
TF101 ICS 4.03
Mike, you mean you don't like the tippy, like the old man that you are? I am ashamed. Maybe I should do a manual swap in the Treg?....
Lol yeah its getting old and I have about 154k on it right now, so I expect the TC to need replaced within a year or two. If I get all the parts lined up I can swap it in a couple of weekends.
Throwing stage 2 at the ZF trans hasn't been best practice but its held up fine. Still shifts great but I want to be ahead of the ball on the 5 speed swap.
Jason I think I got an email back from the Russians. Says he has all the parts but its a B5 A4. I need to do some cross reference, cause I'm not positive everything will work.
