Here's your diags Chris...
Discussion regarding the software diagnostic solution
vVAG-COM Version: Release 311.2-N
Control Module Part Number: 06A 906 032 DL
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 07500
Work Shop Code: WSC 00066
5 Faults Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
P1171 - 35-10 - - - Intermittent
17950 - Angle Sensor 1 for Throttle Actuator (G187): Implausible Signal
P1542 - 35-10 - - - Intermittent
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
17976 - Throttle Actuator (J338): Mechanical Failure
P1568 - 35-10 - - - Intermittent
Sounds like new TB for you. Can I get a second or third opinion from anyone? You can discard the first CB code, as that is a fairly common stored code. We are more concerned with his TB.
CBCGSXR1000
Vehicles: 2
Post by CBCGSXR1000 »
Yes please give any info u got i will order a new TB this week. :nod:
CHRIS
Mill3niumThr33
Post by Mill3niumThr33 »
Yea disregard the catalyst code. I have been battling that one since I bought my car. Search those codes on vortex and see what comes up.
How many miles on your car? You could try cleaning your throttle body or adapting it. They get a pretty bad build up of gunk. I'm pretty sure there is a VAG-COM test to adapt and see how far off the TB is. I did that a few thousand miles ago. Its not to difficult to clean it and it didn't take more than an hour to do. Just follow the DIY guide on vortex exactly how it says and DO NOT TRY TO MOVE THE BUTTERFLY AT ALL. It will destroy the electric motor if you force it.
CBCGSXR1000
Vehicles: 2
Sounds good. Car has 68k on it. :twisted:
CHRIS
FutureStage1
Post by FutureStage1 »
Sorry to jump in on this post but I was wondering if I could use the vag com to change my headlight setting on my car so I can turn on just my fogs? And why not, a quick diagnostic too?
_____________________________
'02 A4 1.8TQ Denim Blue
Doughboy wrote:Sorry to jump in on this post but I was wondering if I could use the vag com to change my headlight setting on my car so I can turn on just my fogs? And why not, a quick diagnostic too?
I'm not sure if you can do it with a vagcom. On the B5's you have to physically modify the lighting module behind the glove box.
FutureStage1
Really? I thought I read somewhere you just hook up the vagcom and a couple pushed buttons makes for an easy mod. What can you do with it then?
Mill3niumThr33
If it requires a ton of work you should go in for an oil change and slip Carlin [One of the cool techs] a couple bucks and I'm sure he could do it for ya.
Doughboy wrote: Really? I thought I read somewhere you just hook up the vagcom and a couple pushed buttons makes for an easy mod. What can you do with it then?
I'd search the archives on Audiworld to see what you can come up with for the B6. I'm sure the question has been asked a lot before. But with the B5 you have to cut out one of the prongs on the headlight module. It's not a difficult mod, it's just a plug that comes out. The trouble is you need hands the size of preschooler to reach it back there.
It allows the fogs to work independently of the rest of the lighting. DOT regs says no fog lights can be on with high beems, so they shut off automatically. Audi also wired it so you can't use fogs alone as a safety percaution. The modification makes them come on whenever you press the button.
FutureStage1
Just curious, aren't the 2002-2005 models considered to be B6 and not B5?
